Old 03-29-2011, 10:43 AM
Mark Johnson Mark Johnson is offline
Default Issues with synthetic rigging?
Can any of you guys with years of experience using synthetic rigging, fill me in on the following?
The comparison that I would like to see between Dux and 316 SS wire, is @ 18 or 20 years old. Of the countless thousands of boats in our area, (Eastern NC), there has only been one dismasting in the last 5 years to my knowledge, and it was a new racing boat under extreem conditions. If one removes from the conversation the < 5% who are cruising all over the world, or live full time in the tropics... The other 95% around here spend winters in the Bahamas, are daysailors & local cruisers, or make a couple of one or two year Caribbean cruises... still spending the majority of their years in our moderate lattitudes, and brackish water. Of this 95% of cruisers, almost all go over 18 or 20 years before changing out their rigging, some even go to 30 years, (admittedly at their own risk)! Has your accelerated UV testing made a compairison to wire at this 18 + year life span, under the above circumstances?
Another point I am curious about... I have switched to some DUX synthetic rigging 6 months back, they are for my running backstays, and DUX seems like a perfect application here. I normally leave them "made up" and fairly snug, to use as a handhold when boarding the boat. When using the staysail, I will put 4 more turns on the "quick adjust" handle turnbuckles, but so far, haven't given them the acid test.
I go to the boat daily, and have noticed that @ 75 degrees F, the runners are quite snug, but @ 40 degrees F, perhaps that same morning, they hang completely limp. Since solid materials expand when heated, and contract when cooled, it can't be that the DUX has gotten longer on a cool morning. I assume that the metal mast has contracted at a rate vastly higher than the DUX, creating loose runners in the morning. Presumably with wooden or composite spars this is less of a problem,. My wire rigging has never done this "changing tune with temperature", and I imagine that it's because the wire expands and contracts at a rate somewhat similar to the metal mast.
With aluminum mast that are long & skinny, (like mine), and dependant on consistant shroud tension to keep the mast in column, wouldn't this become a problem if I tune the rig in the summer, then go sailing on a cool fall day? Has anyone else noticed this characteristic? I have done a LOT of reading on synthetics, and have yet to see this subject brought up...
Best regards, Mark
