Old 01-23-2013, 09:12 PM
Joel H. Joel H. is offline
Default Solent Stay
Greetings, to everyone on this forum.
I hope I'm not being too foreword by making a post like this, my first time here!
Anyway, here goes.....
I discovered this forum while researching the idea of installing a Solent Stay on my 1978 Catalina 27.
I bought the boat 3 seasons ago, and along with a headsail-furler set up with a 150% laminate genoa, the boat came with what appears to be *100% and *130% hank-on jibs. So, of course, I would love to get one or both of them into action.
I sail almost exclusively singlehand so the furler is a must. Also, I really don't want to deal with the expense of installing luff tape on the jibs, and, with constantly loading and unloading them from the foil. Therefore the Solent Stay seems ideal, if it works.
I'm a pretty accomplished mechanic so I feel comfortable installing the deck fittings, below deck reinforcement stays, and mast fittings, necessary.
Also, I plan on installing the Solent Stay close to, and parallel to the existing forestay. Say, within 12" or even less. The upshot is, what I'm hoping is that this will allow me to fly at least the "100%", (without Mods?)
It is probably useful to know that, besides the toe rail genoa track, one of the P.O.s installed additional tracks next to the coach windows behind the shrouds and also at the fore end of the cockpit combing. Oh, and also, if you don't know, a Catalina 27's mast is a tree trunk! So, I'm hoping that all this works to my advantage!
Anyway, I guess the question is: Will the stay itself work? Will the sail/sails work as I am envisioning? Does anyone have any reservations/advise?
*(The sizes don't really match up to the sizes listed on C27 sail guides. The dimensions of the foots are shorter than listed).
Thanks in advance for any feedback,
Joel H.
Old 01-24-2013, 06:34 PM
Hi Joel,
You'll need a halyard, of course--perhaps's there's one rigged for a spinnaker? You'll want to make sure the stay doesn't interfere with the furler arrangement or with flying the jib--it will make tacking the jib difficult, unless you make the new stay removeable, as with a Highfield lever. It seems like if a furler is a MUST for singlehanding, you'll only use the hank-on sails when with other people on board. Do you sail accompanied often enough to warrant the expense and trouble?
Old 01-25-2013, 03:50 AM
Originally Posted by benz View Post
Hi Joel,
Thanks for the reply Benz.
The stay will def. be removable. I'm looking into building a tensioner using a cascade of low friction rings, (Antal), and then lead aft. The stay itself will be Dyneema and will be eye spliced to the eye of the mast fitting, (Gibbs"T-Ball" with eye). I'm also considering using a low friction ring as a halyard block also spliced to the eye of the mast fitting and down to a conventional turning block and lead aft. Hopefully, this will allow for quickly moving a pre-hanked sail into position, attaching the stay and tack, and returning to the cockpit, where it can then be tensioned and raised, all with the limited help of a autohelm or crewmember.
That's the thinking so far. The only real expense will be if I have to get my jib re-cut to make it work. That is the real question!
Cheers,
Joel H.
Old 01-25-2013, 07:04 PM
Making sure the jib will fit before rigging up a whole setup doesn't seem too hard. Lash the tack to the deck, then run the head aloft with the jib halyard and see where it ends up. Choose a calm day.
I'd suggest tensioning the Dyneema forestay from the foredeck, if you have to go up there anyway, rather than leading aft--it'll only take a moment to pull it all tight, and there'll be one less line back there. I use cascading Antal rings for my running backstays, and they work fine.
Old 01-25-2013, 07:41 PM
Great info Benz. Vary encouraging, thank you. I think you have a good point about tensioning at the stay. I'm wondering about cleating that setup. Also do you have any pics showing your backstay cascade?
Thx,
Joel H.
Old 01-26-2013, 02:51 AM
Good point about testing the fit of the jib. I just need to find a day when it isn't blowing or freezing cold. Not a easy thing this time of year, here in Chicago.
Old 01-26-2013, 07:40 AM
[IMG] Uploaded with ImageShack.us[/IMG][IMG][IMG] Uploaded with ImageShack.us[/IMG][/IMG]
I just had another brainstorm.
This may be proof that I have to much fee time, (and am quite possibly crazy!), but:
See photos.
What if the "Antal Ring cascade tensioner" were inverted, so that the final purchase, (the bitter end), of the tensioner was directed up, and fitted with a snap shackle, to became the tack-point of the jib?
Therefore, the loose tensioner and stay can be pulled foreword and, with another snap shackle, attached to the deck mounted padeye. Then the jib tack can be snap shackled to the end/tack-point of the system and hanked on the stay, (obviously this could also be done ahead of time). Finally, when the jib is raised and luff tensioned, the pull on the tack will tension the Solent Stay!!!
Admittedly the power and length of the cascade might have to be experimented with to get the proper ratio of stay tension to luff tension, as well as tack height above deck.
OR:
Also what might be possible would be to install some kind of stopper in the last line of the tensioner(as shown),to limit stay tension and allow for separate luff tensioning.
So, what do you think?
Joel Heberlein
P.S. If you feel the urge to giggle I won't hold it against you.
P.S. If it hasn't been done before, and it works, I'm claiming and naming it.
Old 01-26-2013, 09:11 AM
A comment from someone on Sailnet made me realize that the tensioner stop, to limit stay tension, and allow further luff tensioning, would actually need to be stop(s). In that there would need to be one in every link of the cascade in order to truly lock it.
Old 01-26-2013, 12:41 PM
People on Sailnet have pretty much worked me through the cons of my little halyard/tensioner scheme. I'll still use a cascade but it will cleat off at deck level, and the sail tack will attach to the deck fitting also.
Oh well, I thought it looked great on paper!
Old 01-26-2013, 05:03 PM
Hi Joel,
Good drawings--very clear, and good ideas, even if the details are iffy. My staysail sets in a similar fashion, without any cascading tension, though. The Vectran halyard goes from the head of the sail, through a block aloft, then back down through the sail hanks to a turning block shackled to the stem. There is a becket on the block to which the tack is attached, so the sail is hoisted by pulling upwards on the halyard with feet planted firmly on deck. When tensioned (either by hand or with a turn around the rope drum of the windlass for extra tightness), the halyard becomes a sort of forestay for the sail. Thus the forestay's only use is to hold up the mast, and when dousing the staysail, I unshackle the turning block and the whole circus stows out of the way by the mast, leaving the foredeck free for anchoring or whatever. I find it a lovely system, very quick to set up and stow, without having to hank on and off, since the hanks stay permanently on.
